Results 1 to 11 of 11
Thread: did i miss a speed limiter still top out at 110
    Mar 2018
    11
    removed all the speed limiters I saw im still toping out at 110 I read the tune to make sure it applied it seems to have ill post the one I wrote and the one I pulled after writing to see if different
    all air pump codes delete extra not meme transmission tune + speed + tstat +idle + tm + pe 2007 .hpt
    2ndwrite test.hpt
    ps if you see anything else dumb in the tune tell me most is just copied from a big 3800 tuner from the tuned pcm I got from him
    ill put stock file for refence too
    stock 2007 grand prix.hpt
    Advanced Tuner ZeroBoostBuick's Avatar
    Aug 2008
    S.W. Ontario Canada
    322
    I don't see you missed anything, but sometimes uploading the tune a second time will solve the issue.
    Here are 2 tunes I did on a couple cars a owned before....
    The 98 Regal had many mods non-boosted and ran low 14's down the 1320. Watch out because the timing is fairly high even tho I ran 87 octane, but had zero KR.
    98_Regal-LS-read-sept11-2013.hpt
    The 02' Grand Prix GT is also non-boosted and is stock form and could not get the KR to disappear. but it ran good.
    2002-GP-GT-mild-tune11_Dec31_2014.hpt
    Go through all the stuff and compare to your tune. it will help you figure out how things work. Transmission tables will help the car run more aggressive with out having to give lots of throttle and will not hurt the trans.
    You will have to determine your own timing based on KR. But at full throttle the more the better. As the RPM rise in WOT, I raise the timing and fuel incrementally. It's what the 3800 NA motor like.
    Mar 2018
    11
    alright ill try reflashing I was thinking of doing a write entire but it seem like from what I read that its not needed or advised to do so ill just try a reflash but it going to be a while before I can test going that fast again
    Mar 2018
    11
    well I tried a reflash and I am still toping out at 108-110 it also seem some other settings are not applying that have to do with etc, the park neutral rpm limiter stops at about 3500 I have it set to 5000 just to test and it did not increase. I really don't know what's going on there could be more settings not changing but I don't know what ones any other ideas on this im really thinking of try a write entire to see if that fixes it.
    13,564
    Even try lowering the number to 150mph instead of 255.
    It must take like 2 years just to reach 110mph anyway. My supercharged 2000 GTP even seems like it took forever to reach 100+ with mods.
    Mar 2018
    11
    it doesn't feel like forever but it is downhill. yeah when reflashed it I put it to 250 on everything but ill put it to 150 and see will probably be awhile again before I find out. Im just confused because when I pull it off the computer it has all the values I entered but they seem to have no effect on some things but on others like the transmission changes it works.
    thanks
    Mar 2018
    11
    well I tested it again still top out at 108/110 this is urf
    Mar 2018
    11
    plz halp
    Jan 2004
    Columbus, Ohio
    213
    Can you post a scan showing what happens when you hit the speed limiter? This would be helpful, because then we could see whether spark, fuel or torque management is the culprit.
    2022 Cadillac CT5-V Blackwing (733 whp)
    2022 Cadillac CT4-V Blackwing (716 whp), 10.750 @ 134.77 mph
    2016 Cadillac ATS-Vs (eleven ATS-Vs in the 9s)
    2008 Pontiac G8 (first G8 in the 10s), 10.727 @ 129.87 mph
    2000 Bonneville SSEi (first 3800 Bonneville in the 10s), 10.711 @ 125.71 mph
    1999 Grand Prix GT (first 3800 FWD in the 8s), 8.902 @ 154.90 mph
    1998 Firebird (first 3800 RWD in the 8s), 843 whp, 8.991 @ 152.12 mph
    1998 Grand Prix GTP (first 3800 FWD in the 10s), 9.499 @ 145.13 mph
    I've noticed this too on a buddies car. I thought I had everything set high enough but he still complained about the limiter. Never did get a log of it before he sold it.
    My 04 SS doesn't seem to have that issue, but I'm not certain if I've ever pushed it hard enough to find out where it quits.
    Mar 2018
    11
    didn't get a chance to log it yet but I will, could be a bit again
