Results 1 to 9 of 9
Thread: VE & MAP/BARO (Pressure Ration) E92
    Nov 2016
    10
    Lightbulb VE & MAP/BARO (Pressure Ration) E92
    Hi
    i am trying to tune my VVE table for 2016 Tahoe ls ,but i can find any MAP/BARO (Pressure Ration) PID ?? SO what sensor I should be logging for my row axis for the VE Graph, if can get help on loging the VE for E92 PCM
    regards
    Jul 2015
    5
    Pretty sure pressure ratio was under 'maths.' Cant check while I'm at work.
    Mar 2010
    Texas Hill Country
    3,299
    log MAP Hi Res and Baro pids in Channels
    In Layout you can use the Pressure Ratio math which will calculate from those two pids
    Nov 2016
    10
    Quote Originally Posted by mavericka70 View Post
    i try the pressure ratio maths but the graph not workng
    Nov 2016
    10
    Quote Originally Posted by Higgs Boson View Post
    can you please share with me the layout for the VE logging graph (MAP/BARO (Pressure Ration)
    best regards
    May 2003
    South FL
    1,376
    Quote Originally Posted by doseri View Post
    I had the same issue. You have to add a channel with the Hi Res MAP and BARO in the channel list as Higgs mentioned above. When the pop up box says "you should use this one instead", disregard the message and click the box that says "I KNOW WHAT I AM DOING".
    Then the graph output is easy, there is already a pressure ratio Math PID to select. Just look under the "Maths" folder when building the graph.
    [email protected]
    Owner/GM Calibrator
    Nov 2016
    10
    please can anyone share his config graph for VE Tuning for E92 PCM
    Jul 2018
    5
    any luck? im new to this and running into the same problem. I cant get other places in graft to pop. just keeps me in the 1.xx row through out the columns.
    May 2003
    South FL
    1,376
    It is so easy to do if you would just read the info that has already been posted.
    [email protected]
    Owner/GM Calibrator
