Results 1 to 6 of 6
Thread: 73mm BBK TB installatin issues on F150 2015 EB
    May 2006
    19
    Last Night I installed a new BBK 73mm TB on 2015 EB F-150. The truck started normally but when I go WOT started to backfire and hesitation issues. Any ideas that what can be? Included is the log file? I notice that the TPS does not reach more 40%.
    Jul 2018
    7
    were you able to resolve the problem?
    May 2006
    19
    Quote Originally Posted by Heepz View Post
    Nope, still doing the same...
    Jun 2018
    4
    Not sure if this is the case but did you retrain your TPS? Turn the truck on but don't start and slowly depress gas pedal to the floor and then slide your foot off so that the pedal releases quickly. Turn the truck off and repeat 2 more times. You can also google F150 Throttle Position Sensor relearn.
    May 2006
    19
    Quote Originally Posted by sub_ETCS_ret View Post
    Yes I did.. the actual log is with the relearn.. same issue
    May 2006
    19
    I'm noticing above 3K pull, some limiters goes off.. the driver demand limit source -> "Turbo FMEM" and the Torque Airlimit Source -> "2 Turbo FMEM" and Torque Max Protection Source -> Injector Limit looks that the new incoming air is affecting the whole scenario...
    log4.hpl
