Does anyone have a file for a Stock GTR using VCM Editor 4.0? If so could you post it for us
second that!
2018 mustang gt a10 with headers and e85
I can pull the file on one of our GTRs here if someone is willing to pay credits. Curious if the file will pull parameters from pre existing tune like other platforms or if it can only be pulled from a stock rom file.
its free to pull the file no credits needed
Ahh Blonde moment. I bounce around between 10 different softwares daily. Give me a bit and ill try pulling a file from a flashed and unflashed car. Curious if transmission tuning will be available on these as well. We have extensive testing on this platform so we can work on development and help with support.
Overnighted MPVI 2 to pull file. Old MPVI was unable to pull file on 09 gtrs and other Nissan models. Unsupported interface. Using the latest 4.0 editor. Will update the thread tomorrow with the stock gtr file if all goes well.
I'm just trying to read any Nissan that comes thru right now, tried on a 2011 Murano and it wasn't able to identify the PCM, is there a list to reference to help with which hardware is in what car?
Doc
Doc's Performance & Dyno Tuning - Las Vegas NV . Tuning any and all cars!
Here is the nissan list, You have to use the MPVI2 when you pull the files, the MPVI1 standard and Pro won't do them.
https://www.hptuners.com/vehicles/
Just tried it on ours with a MVPI2 and it read it out but the definition failed to load. Sending it in to support.
Same result. Received MPVI-2 today. Pulled file but checksum validation failed. Unable to view stock rom file. Support ticket submitted.
Just a guess but probably will map to definitions they already have they just have to expand the lookup tables for what definitions to map what kind of thing they use for an ID from a read as they discover new variants. So if GTR has 500 variations they have to map them to the appropriate definition file.
Funny thing you can do with some things like Cobb flashed Fords is open a tune you have and compare to the one you get Definition Failed to Load on. It will compare and show differences. They just don't know how to process the one written with a Cobb OS
Well not that they don't know how to process it just that the system doesn't have it defined for those.
Correct. We defined as many common operating systems as we could, but some slipped through the cracks. If you run into it, just like with Ford, send it in to [email protected] so we can work on getting it supported.
If its not broke, just give it time.
Was anyone able to get the file?
Here is an example file for you.
do i need the mpvi2 interface to be able to view this or do i just need to update my currect vcm suite to the beta version?
i realise i cant read or write to a gtr without the mpvi2 yet would like to look over the tune file
