Originally Posted by
lukearmstrong1990
your MAF HZ starts reducing from 3100rpm.
looks to me like you have a big restriction between your air filter and TB as can be seen with falling MAP value with RPM increase at 100% throttle.
restriction could well be your airfilter
unless you have a vac referenced fuel reg your Injector flow rates are wrong. the should taper up. take your stock IFR table and multiply entire table by the required value to make the 0KPA colum equal to your injector size. if you have a vac referenced reg ignore this part
