Every since I got the LT4 supercharger installed on my Z51, I've had super high IAT and MAT's.
I see others with IAT usually 10-15 degrees above ambient but I experience 60+ degree above ambient. This is just cruising around and not even tracking. When I run 70+ down interstate the temperature don't lower much either.
I've reinstalled the Halltech CAI and made sure everything was sealed. That help by 10 degrees as it was worse. Shop didn't install the sealing strip at air box opening and the round seal to tube was broken and only covering about half the tube.
Should the IAT's be running in the 10-20 degree range above ambient air?
Does this mean the air under the fender is getting to hot and not getting enough outside air?
Using a temperature gun, the intake tube is usually 130-160 degrees when i check it. Is that normal?
What should I check to determine the issue?
Please advice and much appreciated?
A log from last weekend is attached.
Darryl
