Results 1 to 3 of 3
Thread: 4.8 3Bar OS Wont Follow Command BE
    I am stumped as to why this thing wont follow commanded BE tables or PE tables. I set PE AND BE to GM EQ of 1.3 and VCM will not follow those rules. Did that after I realized it wasn't following the PE or BE tables. Had the 2bar OS and everything worked great. Upgraded injectors and went to 3bar OS today and cant get a 11.2 commanded to happen.
    2003 Silverado
    4.8 Single Precision 76/75
    ID850's
    2bar map sensor currently - ZL1 map here next Tuesday
    4l60e 3400 Circle D convertor
    What version are you using of HPT? I tried looking at the file but it wont open. im using 3.6.26 so if your using beta or new 4.0 that might be why. Is your power enrichment table lower than your boost enrichment table?
    Dec 2008
    Nevada
    4,452
    something is wrong with your commanded afr channel. if you look at the commanded EQ ratio channel in your log that one is working fine.
    try deleting that channel and adding it back in
