I have a 2015 1LE cammed sbe LSA conversion unported Blower running around 12 psi ID1050 injectors at 65psi fuel pressure with aem single nozzle 1000cc 100% Meth My question and I?ve been doing a lot of research is but the info is all over the place as far as numbers is What should I be targeting AFR wise or Lambda I?ve had the car anywhere from 11.5- 10.2 Ive been dialing in the VE and maf tables with the stft?s on the scanner the car has been running amazing I did a wide open throttle pull yesterday and it felt really strong I get home to chk the logs and to my disappointment found the afr to be 10.4 avg I?m unsure where to go from here. Why does the car feel better so rich ?
