I am working on my wifes 2002 firebird with the 3.8l v6. it drives well at part throttle and idles well too, the problem comes when you go WOT. what it does is it will pull ok up to about 4,xxx rpms and then it will buck very hard and the timing and fueling goes nuts and I get a lot of knock retard. I have been trying to figure this out for a while now and cant seem to get anywhere with it. sometimes it bucks at 4,000-4500, sometimes its up around 5,000-5400. On occasion it wont buck at all and will run straight up to 5800 or so where the shift point is set. If I let off the throttle while it is bucking it seems to smooth out, and it also would run up to about 5200 in open loop with pe set to 14.7. I only did that to hit the 7500hz like the guide russ k has in the stickies as I didn't want to hurt the motor. the car has a slp lid with a k&n filter, and port matched upper and lower intake manifolds. I don't think anything else is done to the car on the intake side. the exhaust is the factory v6 dual muffler out with a gutted cat that has the shell of the cat still in place. if anyone can look at the log and tune and see if they can figure it out I would greatly appreciate it. I will say that I have put a new MAF sensor on it about 3 years ago, and a new fuel pump and new injectors. the fuel pressure is constant even during the bucking.
WOT MAF run1.hpl
WOT MAF 1.hpt
