The auto saving that he is referring to is that scan file will automatically save you scan when you are done. you will have to search through your files to find it, but it should be in there somewhere if you ever forget to save the scan manually.
I looked at the second log, and I agree that the long term fuel trims or ltft are pretty lean. a positive number is lean, and a negative number is rich. are you absolutely sure that nothing on the truck like the intake or anything that may help the air flow better has been changed? The firebird I have was running more lean than the truck, but I have a port matched upper and lower intake manifold, a v8 style intake and a few other small things to help get more air in it. if nothing else has been changed, then it seems as though like 5FDP has stated, you either have a leak before the o2 sensors or you have a vacuum leak. Since the ltft are the same on both sides, it leads me to believe that it isn't an exhaust leak because I would think that would only register on the bank that the leak is on. I may not be correct on that, but 5FDP knows his stuff, so he will chime in and clarify if I am wrong.
My next question, is do you have a wideband o2 sensor? That really helps dial everything in closer, and in my opinion much quicker than with fuel trims. if so then try to hook it up and get a few logs with it. If not, and you don't plan to tune any other vehicles, then I don't know if I would get one since you aren't trying to make it a hot rod. it would be good to know what the actual afr is when you go wide open throttle though.
check for vacuum and exhaust leaks and see if you find anything out of the ordinary there, and let us know.
