Can some one please share a stock tune for a 2005 GTO M6 with OS 12598977. I just did an Auto to M6 Swap and would like to do a segment swap.
Thank you
Thank you
Here you go.Stock Tune.hpt
'05 GTO E40
'01 TA
Thank you only problem is this looks to be 06 GTO and with OS 12603159. I am looking for 12598977. I understand that if I don't use the same OS number it can cause some issues and maybe brick the ECM.
heres mine
2005 gto m6
kooks signature headers
awespeed intake
Thank you John your OS is 12613269 still hoping to find 12598977 OS
This is pretty close...2005 Holden with LS2 with the same OS.
2005Maloo6.0manualLS2 OEM 1158669910.hpt
Ian B
'15 Holden VF SSVR L77(gone), '19 Ford Ranger PX3 3.2TD, '22 Toyota GDJ150
I have my stock 05 tune on another machine. Will check to see if it is the version you looking for.
Can someone see why I can't do a segment swap given the 2 files below. They have the same OS# granted mine is from a GTO and the other one is from a Holden. The segment swapper stays Greyed out. I have switched from an A4 to a M6.
thx
The A4 wiring harness has a Trans Control Module in the drivers kick panel and is mated to the ECM. I believe that you need to find someone that has the GM test equipment to separate these, and put the 6 speed tune in the computer. I don't think a segment swap will work. PCM of North Carolina has the equipment to do this, but maybe somebody closer can do what you need.
2013 Silverado 5.3, 6L80k 8.8
I separated the appropriate wires witch inlcluded the VSS wires and 2 pairs of can bus wires and have put them into the appropriate pin outs on the ECM.
the car is driving just having some driveability issues that I think are DFCO related.
The tune repository is back up. So i found 2 more 2005 GTO manual files with the correct OS but the Segment Swap is still greyed out.
What am I doing wrong?
