Results 1 to 6 of 6
Thread: 07 Mustang, Comp XE272 cams, Procharged, cam phasers going nuts above 4600rpm
    Jul 2015
    925
    Trying to figure this out. I used the supplied data from Comp for the cams. VCT error looks good till 4600 RPM. At that point, bank 1 tanks rich and the VCT error goes up to 15% or so. Bank 2 has errors, not as bad, but they are all over the place. I swapped WB's from side to side and verified Bank 1 is actually going rich at 4600. You can see on the dyno graph the power falls off some at 4600 but then continues to climb.
    Engine has the Comp limiters installed w/ their valve springs.
    Seeing about 17psi up top with some belt slip after 6300.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    its NA comp cams stage 2 vsr...maybe it helps a little
    Nov 2009
    All Around
    3,149
    try to keep the car in open loop and test again...
    Sep 2010
    43
    Which valve springs 26113 or 26125? Any peoblems controling vct at idle? What oil pump do you have?
    Double chk the cam caps. Seen this issue before and turned out to be cam caps loose enough to cause oiling issues to cam phasers.
    May 2018
    Germany
    586
    no comp cam springs, they are junk.
    eibach springs
    org pump
    no probs
