Guys I?m tuning a 0411 ECM it?s a turbo set up, SD on open loop harness was made with no o2 sensors or MAF sensor. The data of injector I got it from FIC, well I?m having trouble taking out gas at idle, I had to lower my fuel pressure regulator, that work but not sure if lowering will be good, went from 60 psi to 40 psi.
Now will that big of injector giving me problems tuning them? What other way I can do to pull gas? If it?s fine with lowering the fuel pressure it?s ok with me. I will post the file later on I don?t have my laptop with me.
