E38 ls2 conversion fan control
Has anyone played with cooling fan relay control? We have 2 e38 ecu ls2 engine conversions that have been wired to fan output 1 as a relay control switch but fans come on constantly once started. Fan output 1 & 2 have 0 or 1 as a switch but not sure what the axis represents. 1-7 on axis but not description as to what they relate to. I?m guessing a/c, coolant temp etc are something to do with it. We have zero a/c table for fans and set coolant from 95deg. But can?t work out why fan is on constant from start up.
on ecm 18030 if fan desired % reaches 51% at say 95 deg then the ecm 18040 has number 50 in first cell 0-1 will then transition and tell ecm 18045 to transition from row 0 to row 1 which has fan control fan1 with the number row 1 axis box with a "1" (not 0") meaning yes enable relay, if the zero row has any "1" in it then fans will be on all the time, u can also turn each fan state on in the scanner so u know if u have actual control of it or not if u do but its on all the time then it much be triggered by something, if not sure will have to post tune to see what the fan tables look like
Thanks for the info!! Does anyone know what states 3-7 are for?
i think if u had more fans then u could go higher
