Engine: 421cid, Whipple 2.9L, .650"L x 280*, 118 LSA cam. Brodix Heads, long rods, 9.6:1CR. AC driven intercooler setup for blower. Trans is now a full manual, reverse pattern, 4L80. Only thing hooked up is the trans brake and speed sensor.
Car: 2004 GTO
- Initial start: I have to crank it, stop, then crank again. It'll always fire on the 2nd attempt. It comes to life very lazily. Slllloooowwwwllly builds RPM from about 400 and then climbs the ladder to 800. Once it fires it's rough. Surges up/down until the ECT gets north of 130F. Then it'll start to settle down. If you turn the AC on during that time for the chiller, it'll really struggle.
- Once warm: It'll usually idle ok. Maybe a little surge here/there. Put it in gear and drive off and it'll often backfire out the exhaust. Then it'll kinda surge forward and sorta "clear its throat". -like its rich and loaded up or something.
- Down the road its not so bad. Fairly smooth.
- Full power. Good, but I know there's a lot more left.
- Coming off power. It comes back to idle most of the time. It will however occasionally die. Enough to where I find myself using my L foot to brake in case I need to peddle it back to life. Once I blip it, it typically settles down again.
- Off idle power, as in, leaving a light while driving normal. A hesitation, then it goes. Not always though.
- Fuel economy seems to suck royal ass. Not that this engine was built for that of course, but I would think it'd be better than what it is.
- Last: This log didn't have the WB hooked up. So, likely useless I'm betting. I have a Ballanger 500 v2. Just no time to set it up before going to work. One question regarding that. I can't seem to figure out how to get it to output Lambda. I see where the settings tab is, but it won't let me. Any ideas on that?
Thanks for looking
Current tune and latest log:
