Results 1 to 12 of 12
Thread: P12 Flash with MPVI2
    Apr 2018
    Canada
    50
    So i had a unsuccessful flash last week and have one potential bricked ecu. Waiting to hear back if i can get a Tech at a GM dealer to flash it. But was told to use the Beta VCM suite as they fixed the issue. Whatever it was. But before attempting to try again and lose potentially another ecu I would like to hear back if anyone else has tried and been successful.
    Apr 2011
    Chicago, IL
    763
    did you get it handled - ive had a flash fail on me before and i just reflashed it and was g2g - but not on the mpvi2 - pro version not out yet
    Jun 2018
    6
    I had issues with my p12b using the MPVI2. I read it without any issues but when I tried to flash, it connected, loaded bootloader, started erasing and stopped. I couldn't reconnect for quite some time. I was able to connect 3 different times and all got to the same point and failed. I disconnected the after market radio and amp beforehand and nothing so I pulled the on-star fuse just for Shits-N-Giggles made sure my headlights were staying off and turned off my interior lights all while the charger was connected to the vehicle. I'm not sure what the problem was but it finally worked and has worked several times since then without failing.
    Apr 2018
    Canada
    50
    They rolled out a fix in the beta vcm suite that was supposed to have fixed the issue. It's flashed now and working. But not in the original ecu I flashed. The original ECU is bricked. I'm trying to see if a tech2 can recover it but haven't heard back from the GM tech yet. At least you where able to get it to work. I tried pulling the aftermarket adapter as well. No OnStar but I tried everything I read
    Jun 2018
    35
    I think I have one bricked also now. My P12 looks like it's stuck in the receiving data mode or something. No software will even communicate with it, even the Beta. I've tried many, many times now and doesn't even show any signs of it will ever read it again. Ever flash would time out on the bootloader, but would always work the second time. I don't know if that is what happened this time or what.
    Apr 2018
    Canada
    50
    That's what my original did. Still have not heard back from this GM tech yet. So not sure if even a dealer can recover the ecu. So now I do have a spare ecu just in case. Thinking about swapping to the E67. Seems these p12s are pretty much just shit for the most part and hard to come by at that
    Jun 2018
    35
    I was able to recover it using software and firmware released since my last post. All is good once again. I did buy a backup P12 on ebay for $28. I haven't done anything with it yet. As long as I have it, I'll never have to use it.
    Apr 2011
    Chicago, IL
    763
    good to hear
    Nov 2024
    2
    Quote Originally Posted by ctuinstra View Post
    hi, I have the same problem with P12, how did you manage to solve it????
    Advanced Tuner omega_5's Avatar
    Aug 2005
    Maidstone, SK
    483
    Which MPVI are you using?
    Have you tried to flash in regular (non-high speed) mode?
    Nov 2024
    2
    MPVI2
    yes
    I tried everything and still got no satisfactory results. maybe someone has a file to write to bin ???
    Aug 2005
    Maidstone, SK
    483
    Unfortunately, the MPVI2 isn't great with the P12. The MPVI3 is more compatible.
    With the BIN file, are you thinking of using a certain open source tool instead?
