So I have my wideband set up and running. I have not been able to get a a channel setup for this input. tried a friends serial to usb for his mpvi 1 with no luck. Have tried the AC pressure line setup with no luck. All available walkthroughs including the VCM scanner help section are for pre 3.0 scanner software.
Can a pre 3.0 scanner software be downloaded or can someone tell me the trick with custom pids in the new tables?
