I recently installed a set of 345's on my Z06. Every since the install the Engine Drag Control system becomes active on hard decel. I think the taller size tires is putting the rear wheel speed sensors on the edge of telling the PCM that the tires are about to break loose.
I tried making some adjustments in the speedo tab with no luck and think I did something wrong.If I just enter the new tire size height and hit commit.....should that be it? The first time I enter the current rear gear which was wrong as the value needs to be 1. The problem I was getting after playing with it was the speedo was off big time.
Can someone please confirm how to do this?
