My car is finally up and running thanks to Ben, and AFR is mostly dialled in. The is running fantastically, but I'm still a little worried about knock, or more specifically false knock pulling timing out where it shouldn't.
I've got the standard TPI knock sensor installed in my 400SBC, and it's showing between 2-4 degrees of knock just about all of the time.
The funny thing is it disappears if I go WOT so I'm guessing this must be vibration or something causing it to register a false result.
The exhaust is a pretty tight fit on the some places, so it could very likely be that, but I don't want to rule out an actual knock.
Does anyone have any settings for the knock sensors to use either the TPI one, or I have an express Van knock sensor as well that I could use.
