MAF Logging
Im trying to log the MAF in lb/hr in vm scanner and no matter what maf parameter I choose it won't give me ant data. Am I doing something wrong?
2014 Dodge Charger R/T AWD
that car doesn't have a MAF sensor. It's MAP only.
I was thinking that was the case. So in the VCM editor where the is a chart that one of the axis are based on mass airflow like the AIRFLOW>ELECTRONIC THROTTLE>LARGE RANGE or the VE tables that go by aircharge how do I convert that?
There's no need to convert it. There is an aircharge PID you can log.
I tried that before but I got no data. I'll try it again.
When you connect to the vehicle with the scanner, Repoll for support parameters. If it's still not there contact support and have them add it. that's a pretty common PID for these cars.
Yup, just like Jay said...repoll when you are connected to the car
then go to add parameter, type in aircharge to help you locate it quickly.
FYI - there are some links here that give some insight how to set-up tables.
https://forum.hptuners.com/showthrea...he-basic-steps
