Possible to sync a common data element from more than one input file?
Is it possible for RR to be synced with 1 data element that is common in 3 different data input files?
For example, I have 3 csv input files from 3 sources (drone, AirData UAV & Litchi app). Each of those files has 1 data element that is common (GPSTimeDate) which is a long numerical number.
Is there any way to sync all 3 input files so that when I'm syncing the video, everything is sync'd up exactly?
If not, would this ever be a possibility in a future release?
It would be extremely helpful to me since I use 3 different input files, all of which have some elements the other's don't have.
I think you have a good idea but I don't think it is available in the current version. I tend to turn my data log on first and then when ready, start shooting video so my log is always longer than my video. But the video is time stamped so I manually synch it to the data based on this time. Since you are using CSV files, is it not possible to edit the files so that the first line starts at the common GPSTIMEDATE?
Would be great if RR could do this automatically as part of a sync.
