I am working on adapting these coils to a high compression and boosted gm 4cyl application, but figured the Gen3 forum would be a better place to post being the origin of these coils (although the questions are fairly generic).
I found a few stock tunes in the repository from trucks that came with D585's, and the simple solution would be to copy the stock dwell tables over and be done. Since this is a mostly performance application, looking to get a bit more out of them.
I had done some research from other "standalone" ecu applications, and they seem to run a constant dwell time across the rpm range. After looking at the stock tunes, the dwell seems to taper off in the upper rpm.
The only tables my e37 has are the Base dwell table (RPM vs Voltage), and an ECT vs Voltage modifier. At running (really any) voltage and running temp, the modifier is roughly .7X, which pulls the reasonable dwell time even lower.
My question is two parts:
1) Is there any reason I can't (or shouldn't) "zero" out the modifier table with 1's so that I can solely rely on the base dwell table to command the dwell setting?
2) Is there any reason I shouldn't run a constant dwell time across the entire rpm range? Obviously I would need to adjust the dwell time across the voltage axis, but it seems like other performance, non HPT, applications have a constant dwell vs rpm and only adjust for voltage. On a single coil setup I know that you can run into issues with it not having enough time between firing, but was under the impression that it is a non issue on coil-per-cyl setups.
Thank you
