Attached is the log I just pulled. about 2 min long. it fires up without hitting the gas now but it hunts hard to the point it almost stalls. I adjust the TB stop and it is either too much or too little. it will either start and run great then high idle like no other or start like crap and idle well when its warmed up. then if it shuts off it and i go to restart it acts like it has a lot of timing. like a small block with 13 to 1 compression. Any guidance is welcomed!!idle tune.hptrough start up and idle.hpl also right now while idling the WB is reading .86 lambda.
