Results 1 to 2 of 2
Thread: New 6l80 install
    Jan 2007
    19
    New 6l80 install
    Neighbor of mine has a 2011 Silverado that the old trans was slipping. He ordered a new gm 6l80 and installed it. Now the pcm won?t communicate with the tcm. He called me to see if I could do anything with hptuners. I read the pcm and it shows 2 diff operating systems for the trans. Is there anything I can do or does it need to go to dealer for a reflash? I read something about swapping in the old tcm/valvebody might work. With a new trans would that even be recommended if he still has the old trans?
    Oct 2008
    Mebane NC
    475
    I believe a new trans needs to be programmed/flashed by the dealer, Have read mixed solutions, here's one. https://forum.hptuners.com/showthrea...6l80e-question
    If you have the original trans tune you could try it I suppose. When I replaced my TEHCM I got a reman from Dorman they have a fob that will read the original cal before removing it and dump it back into the reman after the changeover.
    Let us know what worked for you.
