3bar SD setup, no start, what am I missing?
I started over with my stock ecm tune on my ecm, converted it to 3 bar sd os , then did a write entire to the ecm, i then changed things like turning off the MAf, turned off LTFT and STFT cause i have the scanner setup for AFR error scanning with the wideband. and I set my fuel pressure reg ( aeromotive boost ref reg) to 58lbs, and the did the calculations for the Injector data as well as called a few that have the same injectors just to make sure i set the data up right.
I did a write calibration to ecm, turned scanner on reset LT fuel trim, all i get is the engine starts then dies no idle. i tried to start it multiple time all with the same result. What am I missing in the software ?
Setup as follows:
6.0 forged bottom end , dish pistons 7:1 comp
6.2 stock truck heads
78/75 turbo
80lb deka injectors
twin 340l intank fuel pumps
2010 zr1 cam 211/230 @ .050 valve lift and .558/.552 lift
LS2 cam sensor in timing cover
Ict billet intake w/102 mm Tb
napa crb219481 3 bar map sensor ( gm 12223861 alt replacement)
wastegate w/14lb spring
