having issues with making video
i have a macbook pro and am trying to make my first video. i am using the video and data from a gopro 6. when i transfer the files to race render everything seems ok. when i either view the video or create the video it freezes and wont unfreeze. i can't see what i am doing wrong. i have tried it with different files and still nothing. any help would be great
Perhaps your mackbook pro isn't up to spec:
OS: Apple macOS? 10.8 (Mountain Lion) or newer
macOS 10.13 (High Sierra) is recommended.
CPU: Intel i5, i7, or Xeon E5 CPU recommended
Intel i7 or better strongly recommended for video larger than 1080p (ie 2.5K, 4K, etc.), or when using multiple 1080p videos.
Actual requirements and performance will vary depending on use.
RAM: 4 GB or more recommended
Actual requirements will vary depending on use.
Display: 1280 x 720 (720p) or larger screen resolution
1920 x 1080 (1080p) or larger is recommended.
More needed if using screen size scaling (common for high-DPI screens).
This is a 64-bit application
