hey guys, so im working on a 98 trans am and for whatever I cannot get it to go into closed loop unless I manually do it in the scanner. Ive checked all the boxes I know of and don't see anything out of line from it entering closed loop. I do see that the passenger side oxygen sensor on shows 20-35mv the entire time. The sensor is a brand new delco unit though that was replaced yesterday... would this cause the issue? Super weird. If any one can review the tune and scan, I would greatly appreciate it! im not seeing any fuel trims on short terms or long terms and from what I can see the car is still running blended VE/MAF confinguration. Whats weird is in my VE/MAF graphs, they are all zero? Heres a run down of the car.
98 trans am
SBE 5.7
MS3 cam
Trick flow heads
Fast intake/throttle body
ram air filter setup
255 in tank pump
green top 42lb injectors
longtubes, 3" y pipe, borla catback
4l60e
Yank 4400 convertor
10 bolt 3.42s
