Results 1 to 7 of 7
Thread: 2018 gt FLEX FUEL
    Nov 2013
    Nashville TN
    17
    2018 gt FLEX FUEL
    orignally i had heard that the 2018 gt ecu would not infer a stoich richer that 11.0 afr roughly with flex fuel. has this been addressed yet, or are we limited to straight e85 only tunes still?
    thanks
    Yes it will
    Apr 2013
    16
    yeah flex works on the 18 no problem.
    May 2015
    427
    I have had some issues setting up the Flex Fuel on my 2018 A10. There are a lot more tables that I have never seen before. And I setup the Flex Fuel how I found worked flawless on the 15-17 with no luck of getting it to function properly. I have made changes to be more specific with the ethanol table to focus on telling the ecu which stoich to target based on ethanol percentage, a tactic that did not work well with the 15-17. It appears to be working better, but not 100% sure yet.
    Kris
    Sep 2010
    872
    Quote Originally Posted by kris5597 View Post
    Kris
    make sure every flex fuel, FFV, and ethanol table is populated correctly. Some of them have values that need to be corrected
    May 2015
    427
    Quote Originally Posted by Jn2 View Post
    Yep, already went through every table in the calibration marked with Flex Fuel or FFV. It seems to be working right now, but I had to setup the Ethanol % vs AFR table to be exact on stoich vs ethanol percentage.
    Nov 2018
    Georgia
    81
    Trying to set this table on mine not sure if this is correct what do you think
