I fired up pro logging the other day, its been a awhile and it won't capture any SAE based channels. I have connected to car and refreshed channels and using the only (RPM) for example channel available to choose. I was able to find non SAE throttle position but still the main ones there is no non-SAE choices. Did the scanner break pro stand alone logging? These channels work fine using the pc scanner and I have written to the config file for pro logging several times.
