What are some common units used in ECU maps?
What units are usually involved in the making of an ECU map?
RMPs, Engine Load (%), kPa, miligram per stroke, mm3, kgr per hour, miligram per revolution.
Any other?
%. Why?s the actual point of your question?
To learn about the various units used in a map. I teach electronics and I want to learn more for ECUs.
Voltage, degrees Celsius, time, etc
Thanks you. Are there any non S.I. units used except the ones I listed?
