ok thanks for all your help really appreciate it ,after I change the pump and injectors , I will need to up the injector flow to injector size correct
Injector flow rate, offset vs volts, short pulse adder, min injector pulse and anything else that the injectors come with.
This is where the data is key. If the injectors you can get your hands on have known data the stuff you input will be easy.
ok I will make sure if not I will get some from summit
thank you
hi I found some injectors in my box of goodies here are spec, are these to big?
Coil Resistance: 12 Ohms / High Impedance
Static Flow Rate: 42 lb/hr = 440 cc/min @ 43.5PSI ( 300kPa )
Gain: 0.12ms/MG
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 300KPa
Amperage: 1.0 Amps
Pressure: Min 30PSIG/ Max 100PSIG
Length: 3" (74mm)
O-Ring Diameter: 14.5mm
