Results 1 to 4 of 4
Thread: 2007 cobalt ss e85 stalling
    Sep 2017
    6
    I just bought a 07 cobalt ss supercharged coupe from a private seller.
    It has a aftermarket supercharger l 80lb injectors and on e85
    He claims to have had a dyno tune I will upload the file
    it surges non stop at idle
    and stalls when ever you let off the gas
    Apr 2011
    Chicago, IL
    763
    whats the full mod list for the vehicle - fuel system mods besides injectors, throttle body swap, cammed, intake...???
    Sep 2017
    6
    harrop blow
    80 lbs injectors
    e85
    return fuel system with boost reference
    zzp 3 inch cold air intake
    header no cat 3 inch exhaust
    dual pass with plan b
    zzp heat echanger
    2.7 pulley
    30k miles
    ls4 t-body
    ported intake manifold
    stock cams
    Apr 2011
    Chicago, IL
    763
    change the etc scaler to 4950 for the ls4 throttle body
    those offsets are from SJSchafer for 60's - i use these from the injector spreadsheet - Attachment 86062 (omega and 04redline) - i use those and they have worked well for me - i don't use the short pulse adders btw
    rpm limit is pretty high if you don't have valve springs imo - unless you have it set to that just so you don't hit the limiter
    20* idle spark? seems excessive to me but ive haven't tuned a e-85 car so maybe you need it that high but also if you have too much ign timing that could cause issues also - factory is set at 10*
