Results 1 to 2 of 2
Thread: Escalade AWD dyno
    Escalade AWD dyno
    Anyone know if you can remove the front driveshaft on a 2013 Escalade with full time AWD and run it on a 2wd dyno? Was reading somewhere there is a procedure to follow and you won't trash the t case.
    No. This is only for 4wd applications. Won't work on awd. I've researched this already because i was trying to see the best way to go if ever my front differential starts hollering. Only way is to put a 2wd transmission in it
