Sometimes the mapped points will weigh to nearest mapped point. The only thresholds we have are Load % and Throttle %. Your distance tables need to go through 0 - 7 before weighing to OP. You might get into OP, then the weight will transfer to the mapped point with the closest cam angles. I'd expect some blending in first and second gear. As your cam angles start to narrow, you get close to 6, 7, 8 and. 7 blends because it has an IVO of -30. Your IVO advanced to -46 and started blending with mapped point 8, IVO -50 but pulled rout and started weighing in mapped point 7, IVO =30. Some of the mapped points are stronger than OP. You can raise spark in those mapped points that are blending . Change your OP cam angles or disable the mapped points. They don't need to be in snap to point to receive weight, they just need to be enabled. Snap to point works with travel of the fuel economy distance table. I take my driving into consideration, I have 11, 10, 9, 8, and 5 disabled. It definitely stops the blending.
First and second gear, had some blending
2nd gear didn't blend because it had time to reach OP.
