Thread: Can I use 2016 ATS transmission's computer on the car of 2017? And then crack it
    Mar 2018
    7
    hi:
    Jul 2018
    Texas
    214
    First you need to determine if the parts numbers of the TCM's between the two model years are the same or a supersession (newer). A GM dealer parts department could tell you that from the parts manual. I would ask HP Tuners directly. Search under VIN swapping. It appears possible.
    2016 ATS-V uses T87 TCM. 2017 and 2018 ATS-V use T87A TCM. I believe HP Tuners will crack the T87A for you.
    1998 Pontiac Grand Prix GTP (first 3800 FWD in the tens), 9.499 @ 145.13 mph
    1998 Pontiac Firebird (first 3800 RWD in the eights), 843 whp, 8.991 @ 152.12 mph, driven by Tim King
    1999 Pontiac Grand Prix GT (first 3800 FWD in the eights), 8.902 @ 154.90 mph, driven by Bob Cook
    2000 Pontiac Bonneville SSEi (first 3800 Bonneville in the twelves, elevens and tens), 10.711 @ 125.71 mph, driven by Ed Morad
    2008 Pontiac G8 (first G8 in the tens), 10.727 @ 129.87 mph
    2018 Cadillac ATS-V, 651 whp
    Quote Originally Posted by tanyangxf View Post
    hi:
    Can I use 2016 ATS transmission's computer on the car of 2017? And then crack it?
    Yes, you can, and you don't need to "crack" or "unlock" it because the 2016 T87 is not secured like the 2017+ T87A is. However, if you swap in a different TCM you will have to somehow code the solenoid characteristics for your particular transmission in it. Not sure how you would do that...
