Does the 2007 and the 2008 TBSS have the same ecu? Read that they may use an E67, is this the case for all TBSS's?
Thanks for the help
Thanks for the help
2005-2006 is E40.
2007-2008 is E67.
06 TBSS is E40 as mentioned above, first year for the TBSS.
07-09 TBSS are all E67, 07 to 08 has a half-step jump and 09 is its own special snowflake. I've had a little success putting an 08 OS on 07 hardware, but I wouldn't recommend it unless you needed to just get home.
~Erik~
2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
~Erik~
