Results 1 to 8 of 8
Thread: New Member - New to Tuning
    Jul 2018
    7
    Hi All,
    Ive heard great things about HP Tuners, and just finished my first engine build/swap (2.5 years of blood sweat and tears). Now its come time to tune this thing, and I almost pulled the trigger on the new MPVI 2 - until a buddy told me i cannot utilize a wideband for tuning on the new system? Can someone please clarify? If the new version cannot utilize a wideband, where can I get the old version?
    Thanks in advance for the assistance!
    28,260
    assuming you are using a CAN based vehicle you can utilize something like the AEM wideband that we sell on our products page https://www.hptuners.com/product/aem...troller-gauge/
    additionally we are working on a solution for those using analog inputs as well, unfortunately the developement window didn't allow us time to deliver both the MPVI2 and the expander hub(for the wideband inputs) at the same time.
    13,559
    If you have an older car that is a GM from like 98-07 using a P01/P59 computer you can always wire the wideband into a 5v circuit in the computer to run the wideband too. Most use the EGR circuit and create a custom channel for it, works great too.
    Jul 2018
    7
    Bummer. Thanks for the reply.
    Jul 2018
    7
    I suppose that would just require a pinout of the ecu correct?
    Jul 2018
    3
    MVP2 What do I need ?
    I am also new to tuning, I already purchased the MVP2 with a couple of credits, I want to use a wide band and have data logging capability, I like the AEM unit you have, can you tell me everything else I need to buy from HP Tuners to give me what I need including Pro upgrade if I need it ? There are 2 vehicles I plan to start with, 2017 Chevy SS (Supercharged) and 2016 Chevy Silverado w/5.3l (stock)
    13,559
    Quote Originally Posted by ls1fc View Post
    Yes, it's like pins 55 and 41 or something close to that. One is the 5v, the other ground.
    Quote Originally Posted by turboshaft View Post
    Nothing really, the can-bus wideband works on both those vehicles.
    May 2006
    Seattle, WA
    539
    Buy an AEM wideband (2 if you want to do one per vehicle) and you have everything else. You can read both vehicles and see what the credits look like, remember if you dont want to tune the FSCM just un-select it as it will cost 1 credit. You probably want to tune it on the SS, if the Silvy is stock should be fine not touching it.
    Edit: 5FDP beat me to it!
    ~Erik~
    2013 Sonic RS - manual, CGM, 6M, sunroof, mods in process
    2008 TrailBlazer 3SS AWD LS2, loaded, dropped, modded, SE22 Performance tuned. And then some...
    2002 TrailBlazer LT 4WD 4.2L I6, lifted, tires, exhaust, SE22 Performance tuned
