EGT data logging
Anyone know if there is a gauge that would allow for the probe to be dual purpose for data logging?
I remember the old Edge Juice modules had terminals on the probe, thinking an amp could be swapped in to interface back to the HP module.
Looking at swapping my gauges out for the Isspro ones and am hoping to be able to connect to the HPT module (after amp is wired in).
That's exactly what you need providing you have the HP Tuners Pro hardware.
I had a customer install a dual probe kit on his pull truck 2 years ago. Using one for EGT and one for pre-intercooler air charge temp.
Here is the complete kit you need:
http://www.exhaustgas.com/ProductDet...pID=&BasketID=
Thanks!
Here is another option, one I will probably go with.
https://www.reveltronics.com/en/shop...-k-type-detail
I would have liked to get a probe setup that I could just unplug from the gauge and plug into the data logger but have not heard back from the gauge company yet on the harness.
Yes... pro hardware. Should be the only option :-)
Ordered this today...
exhaust mani has 2 ports on it, front 3 & back 3... Will be interesting to see the egt data differences.
