Ok, I went through all ten pages in this forum and couldn't find a for-sure answer.
I bought the Zeitronix wide band with a boost sensor. The Zeitronix only has one analog output, the wide band. So to read boost, it would be outside of HP Tuners.
If I understand the enhanced I/O pigtail, I can hook the boost sensor right to it, can't I?
The output of the three-wire, 0-5V boost sensor would go to A/D input 2, 3, or 4; #6 provides 5 volts to the sensor; and #5 is the sensor ground, along with being the Zeitronix analog wide band output ground.
Please tell me if I am correct. Thanks for the help.
Mike.
