Results 1 to 4 of 4
Thread: Channel Values Different From Chart Display
    Mar 2015
    13
    Can someone please explain why the values in the channel pane lag behind those in the charts?
    When I cursor across the chart and see values change in the chart pane, the same values in the channel pane don't change. Not sure if this is a setting in the Scanner? Thanks.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    interpolated between each polling interval. Normal.
    Mar 2015
    13
    Thanks for the weekend reply, Bill. Are you saying that the chart is interpolating the channel data between (in my case 10ms) polling? Such that the "real" data is in the channel, not the chart?
    I am trying to match shift speeds to RPM, so I'm trying to judge which is the best data to use - the channel pane or the chart display.
    Oct 2018
    21
    Sorry for the bump but wouldn't mind knowing which one is correct.
    My chart data varies (especially my WB reading) compared to the channels.
