Doesn't lope in gear
2006 ram hemi idles and lopes good in park. When you put it in gear all the lope goes away. Has stock stall could that be it or is it a parameter I could mess with.
A stall makes all the difference. Needs to be a little loose on the bottom. I've found rams to be the hardest to make lope without lots of work. I have a decent cam in mine and its still hard 234/242 on a 112 LSA Stock verter too
I?m tuning a 04 5.7 and can?t get any lope in PN. Have chafed everything I can find. Will you share your file so I can compare?
You guys need to tune your ve with a wideband. Adjusting to try to get o2 corrections near 5% should get it close.
