Results 1 to 20 of 20
Thread: MAF tuning - error % keeps getting worse
    Sep 2009
    43
    Hi all,
    I did 3 logs yesterday using OL and my wideband to record MAF % error and I thought I was on the right track but on my last log, my errors just shot up and I can't seem to get/keep the error % close to zero. I'm just posting the logs, because the only changes I made to the tune was to multiply by % -error after each log but if you'd like the see the tunes that are associated with the logs I will post them as well.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,472
    Did you go to scanner--clear trims, before you started logging after writing calibration?
    2013 Silverado 5.3, 6L80k 8.8
    Sep 2009
    43
    I did, just out of habit, but does it matter since I've only been logging in open loop?
    Jul 2012
    Florida
    1,472
    Good question. I do it out of habit also.
    Apr 2011
    Chicago, IL
    763
    Im mobile atm so I can view attachments I will later but if you still have fuel trims enabled while doing o/l tuning it will mess with the data
    Sep 2009
    43
    Quote Originally Posted by TCSS07 View Post
    I disabled fuel trims in the tune but I've attached the tune for review.
    Tune 5 corresponds to the changes I made based on the error of log 5.
    Tune 6 corresponds to the changes I made based on the error of log 6.
    Log 7 was run after tune 6 was uploaded.
    Apr 2011
    Chicago, IL
    763
    i actually like the data from how your file was during log 5 - always make sure the injector data is correct
    i tune differently - i just tune in closed loop and get the fuel trims to be + or - 5% to start then switch to o/l tuning to dial it in a little closer (but i usually don't) and for maybe during acceleration cells if i get some lean stumble and then just log my wot fueling against my afr error% vs maf and adjust accordingly because maybe its different for some people but on my car my wide band sways alot (no cat) and makes it hard to get proper data because one log itll be ok for average and then the next log i could be rich or lean for an average
    Sep 2009
    43
    Thanks for the feedback. I'm actually running stock injectors. I thought open loop would be the easiest because I wouldn't have to worry about filtering out PE data. I thought log 5 was great also, and log 6 was just to confirm and get some WOT data for the higher Hz MAF cells.
    I checked the WB for drift and it's reading on point. The only thing I can think of is I must have developed some kind of leak between log 6 and log 7, which is sending unmetered air into the motor. Is there anything in the log that I can look out for that could confirm this?
    Needless to say, I was pretty bummed out after doing so many runs and thinking that I was about to prefect the MAF and be able to move onto the VE table.
    Apr 2011
    Chicago, IL
    763
    I never filter data I just make another histogram logging what I want like make one for command afr vs maf and one for afr error vs maf and just compare against my ltft vs maf histogram and see which cells hit pe but when I tune i dial in my fuel trims with doing normal driving and some acceleration cells - im boosted so I have pe happen around 3psi - for wot data I do a pull from a low rpm like 2500 in a higher gear like 3rd gear like I would on a dyno and which cell it fell in first id consider it wot fueling from there in up
    Apr 2011
    Chicago, IL
    763
    If you want to know for a vac leak pop it back in closed loop and at idle the trims should go positive
    Sep 2009
    43
    Well I threw in the towel for a bit but I decided to take the car out for a drive today without changing the tune. The MAF error % values look much better than log 7.
    I'm pretty confused, why would trims read 8% on one run, then 1%-3% on another run, using the same tune
    Mar 2015
    Alberta Canada
    77
    Was you injector tip temp similar between runs? I've had that throw trims off by 4-5% between a cool morning and a hot afternoon.
    69 Chevelle 418" LS3, 11.25:1,PRC 260 heads, TSP 235/239, Longtubes, dual 3", 4L80, 3.42
    2010 Corvette Grand Sport A6, Heartbeat blower, 78mm pulley/10% lower, Kooks Long Tubes, 224/232 blower cam, ID1050x's, ECS stage 1 fuel system, alkycontrol meth system
    Apr 2007
    1,104
    you need to drive it a few miles before you start logging as you're running against injector temp adders/ibt/inj temp gain.
    The most hated, make the most power.
    93 Ranger. 5.3 D1X. 1069hp.
    Sep 2009
    43
    Thanks for the feedback. I have my injector temp gain table set to zero. Are there other tables that I should investigate?
    Tuner in Training jmanson62's Avatar
    Aug 2018
    Idaho
    18
    SS, I too have run into this. I found that logging a run in the morning and then without changes log again in the afternoon, my trims will go leaner. It's my understanding that air temp has a lot to do with it. I've read on other sites that when tuning try and stay consistent with weather and pressures. Just my two cents.
    Mar 2015
    Alberta Canada
    77
    Quote Originally Posted by ssbowtie1 View Post
    That is really not the correct way to do this. By zeroing out that table you run the risk of running very lean at high temps. You're better off spending some time actually calibrating that table rather than zeroes. There are a couple good threads on here about it.
    https://forum.hptuners.com/showthrea...ector+tip+temp
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    Regardless of what may be on the internet. ZEROing injector temp gain table is VERY bad. Just because it can be done does not mean it should. It will result in excessively rich and lean extremes depending on conditions.
    2012 ZL1 - Maggie Heartbeat, Port & Polish Heads, Custom Cam, Custom rotating assembly, steel sleeved LS9, No NOS and No water meth. 16psi
    810rwhp and 820rwtq 91 Octane 6400 rpm
    948rwhp and 951rwtq 105 Octane 6400 rpm
    999rwhp and 997rwtq on 60% Ethanol 6400 rpm
    I thought you only zeroed it out while on the dyno in a controlled environment, then you set it back and dial in temp compensations as you identify issues when driving.
    Mar 2018
    Florida
    44
    Quote Originally Posted by superman07 View Post
    This is also what I took from it... just for the dyno and then back to stock or where ever it was before once you were done.
    2019 Corvette Grand Sport Black
    2018 Camaro SS Bright Yellow
    Sep 2015
    Bozeman, MT
    701
    Guess if you are looking for an excessively lean condition while placing your engine under extreme stress. That would be one way to do it. Not how I would recommend running the engine.
