Originally Posted by
killercolt
Here is the basic. Most cars have an after start enrichment that give the cars extra fuel for a few seconds or minutes. On your car, the section you want to tune is under Air flow->General->Cranking Airflow and Torque->Base Air Flow. Highlight the whole Base Air Flow table and multiple it by 2. You can lean or richen it later with other numbers or multipliers but start with doubling the numbers and watch the initial start up AFR.
What this will do is give you extra fuel on the initial start up to catch the idle. Tune it to get the car to start up at 12-13:1 AFR and then the car should transition to 14-15:1 AFR after the. You want to do this with some cammed cars too because it will need that extra fuel to stabilized the idle during initial start up. Really it can be apply to any cars that need extra fuel after the first few seconds or minutes of start up. Good Luck.
