Results 1 to 4 of 4
Thread: Aem 30-0310
    Dec 2005
    Texas
    254
    Aem 30-0310
    Friend has an AEM 03-310 wideband that I will be using to tune his car. HPTuners has a default option for this wideband, the range is 8-18 AFR ( I tune using lambda) but according to AEM documentation the range is 8.5-18 AFR (.58-1.23 lambda), is the scaling for the default setting correct for this wideband?
    Dec 2005
    604
    The scaling is :
    0.500v = 0.5800 Lambda 8.526AFR ( Using 14.7 = stoich )
    4.500v = 1.2285 Lambda 18.059AFR ( Using 14.7 = stoich )
    Dec 2005
    Texas
    254
    Thank you, but the question was more targeted to the accuracy of the default settings. I didn't have my laptop with me so I couldn't confirm. I just checked the formula and it is correct. Thanks again.
    (V/.42105263)+7.3125
    Dec 2005
    604
    The lambda function is ( V * 0.162125 ) + 0.4989
    AFR function is ( V * 2.3832 ) + 7.3344
    So (V/.42105263)+7.3125 would be right for stoich=14.65. Which is the conversion that AEM uses for the display on the gauges. But, most people use 14.7
    Bottom line. if you want to get lambda from that conversion, divide by 14.65 not 14.7
