you can be the best tuner in the world but if the ecm only allows up to 63lb of injector flow it will only allow up to 63lb of injector flow and by not having the the ability to change the flow rate modifier you cant alter/trick the ecm to flow more so all i can suggest is scale the injectors down and tune maf and or ve or keep trying support and hopefully they get back to you and or maybe its something they overlooked
