The top MAF value probably went over the limit but it should cap out when you save it anyway and not be an issue.
If you hover over the entry rate it should give you a range of values. Just set it to the highest value and move on.
The TPS for PE should be in the PE tab. It will be a table and should be set at 90% from the factory. There is usually a hot and a cold value.
