Originally Posted by
jw44
PATS may still be an issue, but you should know pretty quick. You should be able to disable the ABS and TC. There are several torque tables that can also cause issues. What transmission are you using?
With almost everything set to factory settings I had a hanging idle and really slow return to idle after reving the engine. I went into Engine>Idle>General and disabled Torque Decel Switch. I then changed Engine>Idle>Airflow Dashpot Clip/Clip vs RPM and change it from 0 to .75 in all tables. The RPM goes right back to idle after you rev now.
I have a '91 mustang with the 3.7/mt82 swap
