2018 Raptor - torque management
Hey there, hoping someone can give me a quick run down on torque management. The problem I'm having is with the TPS closing and limiting airflow. Please see the attached log. log raptor tps.csv
Is it at all feasible to disable "desired air mass" and then work with the wastegate duty tables to get the desired boost level? What's the best approach? Thanks for your help!
No, don't do that. Let the throttle close to control boost, imo, it's a much better method and requires almost no logging/extensive adjustments to the tune.
Instead work with your driver demand table 100% column and your desired pressure tables in the turbo tabs. The (stock) ecoboost is surprisingly simple to tune once you understand the logic.
