I have searched the forums and haven't found anything.
I have been trying to figure out how to change camshaft timing on this vehicle (I've been successful on other DCX). I've changed all values on camshaft page and the camshaft does the same thing no matter what the values have been set to.
Are there any settings that influence cam timing but are not on the cam timing page?
I have adjusted every single table on the variable camshaft page and have not been able to influence cam timing @ WOT.
For the purpose of testing whether or not the tables on the page were active at WOT I changed all exhaust tables to 127 and intakes to 114. Logging this car while stock, showed camshaft intake exhaust intersecting at 127ecl/114icl for 114ICL.
edit: I wanted to sample power @ 114ICL which in this setup = 127ECL. Actual logged cam timing has done exactly the same as the log attached no matter the values I enter in the cam-timing tables.
runfile14.hpl
21.hpt
Any ideas?
Thank you.
