Originally Posted by
zhc
WOT - Base is the table that is used most of the time. The other tables are used when certain conditions apply like if the car is operating in cat over temp mode.
WOT Thermal - This table is used when the car is in cat over temp protection. In a stock tune, this mode is triggered when exhaust gas temps reach a certain threshold. Refer to the Fuel > Temperature Control tab for a look at the parameters that controls this mode. There are tables elsewhere that do something when this mode is triggered, like FA enrichment and spark.
Lockpin - These tables are used when the cam is in lockpin position.
MBT - Hopefully you understand the concepts of MBT. If not, there's a bunch of good reading material out there that explains it better than I could in a post. With that said, this table acts like a limiter to prevent timing from advancing beyond what's defined in this table.
Aircharge is the calculated amount of air that is in the cylinder for each combustion event. It does correlate to boost/vacuum where 0g aircharge would theoretically be a perfect vacuum and at some point vacuum becomes boost. It may help to log the "Aircharge" channel in VCM Scanner to see for yourself.
